I have created Incremental Refresh and set the Scheduled refresh of the report in the service over night NZ time 1.00AM.
The refresh failed both times ( only set the schedule to start on Sunday night). I also get the same failure message if I push the refresh through from the service manually
This is the failed message that Power Bi, any ideas on what may be causing this failure, could it be the way I have set up the incremental refresh?
My dear Friend @AoakeP,
As the error is showing that while refreshing data , the new data which was to be merged had some issue with the data format of date/time type .
Please check your data and see whether it is of date type .
I am sure this will solve your issue , if you change data type of the date column .
Please let me know if you have some doubt.
Will be more than happy to help
Hi @AoakeP, we’ve noticed that no response has been received from you since the 18th of August. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
Sorry its taken a couple days to post back, I tried the suggested changes and the incremental is still failing, at this point I’m not sure what to do next to get to the bottom of the issue, so I have removed incremental refresh from my model for now.
