Scatter plot min & max by measure
Is there a way to use a measure on a scatter plot to set the start and end for the Y and X axis instead of typing them in manually ?
I have tried some of the custom visuals but the visuals either don’t work or don’t have the feature.
Thanks,
Tim
Hi @Timmay,
Are you sure you have the latest version of Power BI ?
When I’m looking in one of my PBIX files, I can set up the min and max of X/Y axis with a function.
Or maybe it’s because of the measures you put in the X Axis and Y Axis.
With your PBIX file, I could try it :wink:
Best regards,
JBocher
solved by an update, thank you!
