SAMEPERIODLASTYEAR with two filters
Hi all,
I’m preparing a sample PBIX file but wanted to post my question in case one knows an answer.
From 100 products that we make we actively plan/forecast only 40 or so. The rest is non-planned based on last years (LY) numbers. Everything in this report is on a daily basis.
We have a full fiscal year monthly budget, that I broke down in daily numbers.
I have the daily actual produced products. All dates in the past have only actuals against budget.
For future dates, (>= today) I take the value of the 40 planned items + the LY numbers of the 60 items.
I managed to get the measure of LY figures for those that do not have a planned item number, i.e. are blank:
Non Planned Items Plan MT =
CALCULATE (
[Actual MT],
SAMEPERIODLASTYEAR ( dim_date[Dates] ),
FILTER (
dim_Item_Attributes,
dim_Item_Attributes[Planned Item Number]
= BLANK ()
However, this measure returns the LY figures for all dates. Once today has passed, this should be blank and only actual remain. For >= today, it should show plan + LY nonplanned.
I tried many different calculations, but they all return blank. Here’s one which I thought to just add another filter in it, as this worked with other stuff as well.
CALCULATE (
[Actual MT],
FILTER (
= BLANK ()
FILTER (
dim_date,
dim_date[Dates]
>= TODAY ()
In the image the orange numbers should be blank. (Same as the Plan MT is blank < today).
I’ll be working on a PBIX sample file, but if you already have an idea, please let me know.
Cheers
Kat
I think the issue is with the model getting the data from a direct query. I thought a workaround through SELECTEDCOLUMNS would do the trick, but the DAX behaviour is different than from stored models.
I don’t have the issues in the sample file, so that’s my only explanation.
Cheers
Kat
@Kathi You can do a simple IF condition to check IF ( SELECTEDVALUE ( Dates[Date] ) >= TODAY(), [Non Planned Items Plan MT] )
Hi @Kathi , did the response provided by @AntrikshSHarma help you solve your query?
If not, kindly send the PBIX file so the other users can help you with your inquiry further.
Hi @Kathi, we’ve noticed that no response has been received from you since September 20.
Hi @Kathi, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please create a new thread.
