Hi all,
I am trying to build a delivery report and I would like to count the # of orders delivered On Time/TooLate/Not Delivered.
My issue is that for a same Order ID I sometimes have different Delivery Status, when some items were not available for example.
See the example below :
In this case I would like to consider the order as part of the ‘‘Not Delivered’’ ones even if some items have been delivered “On Time”.
I am really struggling to find the best approach ? Or what DAX functions would be helpful ?
Thanks a lot in advance
Best,
Marie
Marie,
Hi, is there any way you can send a pbix file of your data so we can look into this further.
Guy
Hi Guy,
Here it is :
SalesStatus_Count.pbix (43.8 KB)
Many thanks !
Marie
Marie,
I’m enclosing a revised PBIX file with my changes. The new measures I created are in the Key Measures table (a strong recommendation by Sam).
Hopefully this helps. I suggest you look into Variables on Sam’s EnterpriseDNA site and also on his YouTube channel - very good stuff.
Guy
Guy thank you very much for all your help ! This is exactly what I trying to do
I will check the videos as well.
Have a nice weekend !
Marie
Marie,
Glad I could help. Enjoy the videos
Guy
