RowsToColumns in Power Query
Hi All,
Thanks for replying the queries.
I am working on sales data and want to convert OrderNumber and Date as row headers .
I have data in the form of transactions.
So,I am attaching the screenshot what I want to achieve.Please suggest how to do in Power Query Editor.
Ordernumber.xlsx (8.9 KB)
Hi Nisha,
here is one possibility:
let
    Source = Excel.CurrentWorkbook(){[Name="Table1"]}[Content],
    #"Added Custom" = Table.AddColumn(Source, "Custom", each if [Column1] = "Ordernumber" then [Column2] else null),
    #"Filled Down" = Table.FillDown(#"Added Custom",{"Custom"}),
    #"Pivoted Column" = Table.Pivot(#"Filled Down", List.Distinct(#"Filled Down"[Column1]), "Column1", "Column2"),
    #"Removed Columns" = Table.RemoveColumns(#"Pivoted Column",{"Custom"})
in
    #"Removed Columns"
Regards,
Matthias
Thanks Matthias for your response
But I am not that much good in understanding M code because I am in learning phase.
Could you please explain it through Power Query steps?
Nisha, I took an easy version where the step names do explain what is done:
#"Added Custom" => whenever there is an Ordernumber that number is taken
#"Filled Down" => the Ordernumber is filled down
#"Pivoted Column" => rotates the data in Column1 into column headings
#"Removed Columns" => takes out the Custom Column, as it is a not needed anymore
In any case you can copy the code and bring it to the advanced editor and then see step by step what is done. I think that will help you understand.
Thank you so much Matthias.The problem of transformation of columns has been resolved.
But ,2% Error I can see in my data while performing it .
I have date and Ordernumber both but its showing error in these rows stating
Expression.Error: There weren’t enough elements in the enumeration to complete the operation.
Details:
[List]
Note:I have checked there is value for both date and order then why I am getting this error? Not sure
Could you please have any suggestion?
Nisha, how does the data look in the area of 34012 to 34015?
Thanks Matthias ,I had duplicate copies in the data source so the issue was there
Its resolved now, thank you so much.
Thanks Nisha for the feedback. That makes sense.
