I have a paginated report which is using Power BI dataset as source. Some users complain that they can’t see data in the report. How do I check or impersonate it in Paginated report, the way we can impersonate Power BI reports?
Hi @rit372002, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
