Hi @Sam,
is there any way to change the color of row headers in a matrix based on the value?
Thanks for suggestions
Roberto
ColorMatrixRowHeader.pbix (71.7 KB)
Hi @Sam,
Roberto
I might have found a solution.
The matrices seem cannot it, but tables do, so I’ve faked using some measures.
Not perfect, but it will pass the UAT!
Any suggestion is still very welcome!
Roberto
ColorMatrixRowHeader.pbix (72.2 KB)
You have probably found the best solution for now - I was unable to find a way to do this with the matrix table. I have looked at a few of the custom visuals, but not found any that seem to do the trick.
Best alternative I can think of would be the Charticulator visual - but I don’t have the time right now to dig into this further.
Hi @Heather,
thanks for you post. Actually Charticulator seems to be the answer to all stock visuals limitations, but I’ve never had time to go beyond the basics of this promising tool.
Regards
Roberto
