Rolling Sum Issue
Hi Folks, Am trying to calculate a simple rolling sum using the following dax but the result is just way off wrong
Rolling Sum (dollars) =
Var __Sum= SUMX(‘Inventory Balances Components -Report R5841003’,[Quantity On Hand (Dollars)]) + SUMX(‘V3411L - MRP Detailed Message Review’,[Quantity Available (Dollars)]) + SUMX(‘V4311CC - Open Orders’,‘V4311CC - Open Orders’[Open Orders (Dollars)]) - SUMX(‘V3412A- MRP Pegging Inquiry’,[Quantity Ordered (Dollars)])
VAR RollingSum = CALCULATE(
__Sum,
FILTER(
ALLSELECTED(DateTable),
DateTable[Date] <= MAX(DateTable[Date])
Return RollingSum
I added all the measures that are used for the rolling sum,
today should be 55,279 (40,962+0+14317-0) then 55,279-3092=52,187 but its just summing each month up.
All the columns in the addition are measures, could that be what is affecting this
This is driving me nuts, Plssss help
I am calculating rolling sum on other columns too and it works
Rolling Sum Qty W/O -ve inventory =
[Sum of Quantities],
FILTER(
IF(
RollingSum < 0,
0,
RollingSum
Have you tried out data mentor on this.
Perfect for this type of thing. I worked through a few iterations.
Another one
Thanks Sam but the running total calculation suggested didnt work. the date table exist
The rolling sum Dax calculation I have works now but something seems off when I roll it up for some reason to another category. on the Area bar chart, i noticed the roll up is still picking the intermediate calculations in the DAX.
This is what i did for clarity sake, I created a sum of quantities
Sum of Quantities = SUM(‘Inventory Balances Components -Report R5841003’[Quantity On Hand]) + SUM(‘V3411L - MRP Detailed Message Review’[Quantity_Available]) + SUM(‘V4311CC - Open Orders’[Open Orders]) - SUM(‘V3412A- MRP Pegging Inquiry’[Quantity Ordered]).
then calc the rolling sum as Rolling Sum Qty W/O -ve inventory =
FILTER(
IF(
RollingSum < 0,
0,
RollingSum
what i expect to happen is as follows
But I am guessing this is what is happening
This behaviour might be correct or my Dax calculation is just totally off. Can someone point me in the right direction
sample model.pbix (666.9 KB)
