I like the ridge plot @Greg shared in Deneb Example - Ridge Plot.
The separate set of layers for each month resulted in extensive, repetitive code and that had me convinced we could optimize with some transforms. I was worried about scalability and maintenance.
I made an attempt at keeping all of Greg’s settings intact.
Instead of separate layers for each month, I use a single area layer, a single baseline rule layer, and a single label layer. I used transformations to group and process the temperature data by month, allowing the plotting of all months within the same layers. and I used calculations to position the ridgelines.
These change resulting in 1300 lines vs. 259 lines. the color scheme I chose doesn’t really work because the earlier month labels are near transparent. That’s an easy thing to fix.
"$schema": "https://vega.github.io/schema/vega-lite/v5.json",
"title": {
"anchor": "start",
"align": "left",
"offset": 20,
"text": "Example Ridge Plot, Deneb/Vega-Lite",
"font": "Verdana",
"fontSize": 14,
"fontWeight": "bold",
"fontStyle": "normal",
"subtitle": [
"Daily Temperature Distribution, 1950 to 2020, International Airport, Ottawa, Canada",
"Data Source: Environment and Climate Change Canada (https://climate-change.canada.ca/climate-data/#/daily-climate-data)"
"subtitleFont": "Verdana",
"subtitleFontSize": 12,
"subtitleFontWeight": "normal",
"subtitleFontStyle": "italic"
"data": {
"name": "dataset"
"width": 1140,
"height": 490,
"transform": [
"calculate": "_temperature_statistic == 'Maximum Temperature' ? datum['MAX_TEMPERATURE'] : _temperature_statistic == 'Minimum Temperature' ? datum['MIN_TEMPERATURE'] : datum['MEAN_TEMPERATURE']",
"as": "_temperature"
"calculate": "month(datum['Date'])",
"as": "_month"
"calculate": "timeFormat(datum['Date'], '%B')",
"as": "_month_name"
"calculate": "11 - datum['_month']",
"as": "_reverse_month"
"calculate": "datum['_reverse_month'] * _month_y_increment",
"as": "_month_y_offset"
"params": [
"name": "_temperature_statistic",
"value": "Maximum Temperature",
"bind": {
"input": "radio",
"options": [
"Minimum Temperature",
"Mean Temperature"
"name": "Statistic: "
"name": "_month_y_increment",
"value": 0.03
"layer": [
"transform": [
"density": "_temperature",
"groupby": [
"_month",
"_month_name",
"_month_y_offset"
"extent": [
-50,
50
"as": [
"_kde_value",
"_kde_density"
"calculate": "datum['_kde_density'] + datum['_month_y_offset']",
"as": "_new_kde_density"
"mark": {
"type": "area",
"opacity": 0.6,
"interpolate": "monotone"
"encoding": {
"x": {
"field": "_kde_value",
"type": "quantitative",
"title": "Temperature (°C)",
"axis": {
"domain": false,
"labelFontSize": {
"expr": "datum.value % 10 == 0 ? 14 : 10"
"labelFont": "Segoe UI",
"titleFontSize": 16,
"titleFont": "Segoe UI",
"gridColor": {
"expr": "datum.value == 0 ? 'black' : datum.value % 10 == 0 ? '#969696' : '#E3E3E3'"
"gridWidth": {
"expr": "datum.value == 0 ? 2 : 1"
"tickSize": {
"expr": "datum.value % 10 == 0 ? 14 : 8"
"tickColor": {
"orient": "bottom"
"scale": {
"domain": [
-50,
50
"y": {
"field": "_new_kde_density",
"axis": null,
"scale": {
"domain": [
0,
0.45
"y2": {
"field": "_month_y_offset"
"color": {
"field": "_month",
"legend": null,
"scale": {
"scheme": "reds",
"domain": [
0,
11
"tooltip": [
"field": "_month_name",
"type": "nominal",
"title": "Month"
"title": "Temperature"
"field": "_kde_density",
"title": "Density"
"transform": [
"aggregate": [
"op": "min",
"as": "_kde_value_min"
"groupby": [
"_month",
"_month_name",
"_month_y_offset"
"mark": {
"type": "rule",
"color": "transparant"
"encoding": {
"x": {
"value": -50
"x2": {
"value": 50
"y": {
"field": "_month_y_offset",
"transform": [
"aggregate": [
"op": "min",
"groupby": [
"_month",
"_month_name",
"_month_y_offset"
"mark": {
"type": "text",
"yOffset": -10,
"fontSize": 12,
"font": "Segoe UI"
"encoding": {
"text": {
"type": "nominal"
"x": {
"value": -49.5
"y": {
"color": {
"field": "_month",
"scale": {
"scheme": "reds",
"domain": [
0,
11
"legend": null
