I would like to know if there are any tutorials of how to reuse this dataset that is published to power bi portal. In Tableau, we publish enterprise extracts to viz portal so that business can use those to perform visualizations. So, if a tutorial having publishing enterprise datasets will be very helpful and also more tutorials on publishing and using power bi portal will help.
Thanks in Advance!!!
Thank you. I am wondering if there are any recording material by Sam which gives more detailed information and best practices for data sets
i have not seen any recording material by Sam on this subject but here are 3 links to get you started
Thank you!!!
Hi Sunip,
Hope you are doing good.
you can check this tutorial also,
Thank you!
You are always welcome
