How is it possible to construct a PowerBI dataflow that can retrieve more than 2000 rows of data? The current default data limit is 2000 records which needs to be expanded to retrieve 4000 records. Is there a setting that can be applied to retrieve more than the 2000 record limit for a dataflow? In the example provided a web api call is being made to retrieve data from RALLY.
@jfarland1118
unless you have any filters placed in the dataflow, it will pull all the data available in the source.
Since you mentioned you are getting data from an API, i am quite confident that its the API that has some kind of default limit set to it. and its common Api’s to set a limit generally by pagination.
id recommend that you read the documentation of the API in detail and modify your m code accordingly. That should help you.
To build upon the discussion above, I did find out the WebAPI being used is only able to retrieve 2,000 records at one time. Does anyone have any M code to do recursive data source calls until all of the records in the query are retrieved? For example, if the data source contains 5000 records, there would be a total of three recursive data calls in M to retrieve all of the records
