Is there a way to reset slicer filters without using bookmarks?
Hi ,
Can i know what is your use case .Where you want to use reset because you can rest any filter by one by one go to them and erase the selection.
Thanks,
Anurag
If you’re talking about in the service you can press Reset to default to reset things
The scenario is that if there are many slicers/filters that you’ve set in your report and need a quick way of resetting all of them. This would be in Power BI desktop.
Hi @powerbideveloper. AFAIK, no … a bookmark would be required to reset multiple slicers at the same time in desktop.
Hello @powerbideveloper, just following up if the response from the experts and users above help you solve your inquiry?
If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution
