Reset filters, refresh datetime
Hello,
Do you know how and if you are aware there is a video regarding the below questions on this website?
Question:
1-
I have several slicers on the page.
How is it possible to reset these filters?
2-
How is it possible to show in a textbox on the page when the last time the dataset was refreshed?
Thank you
@arkiboys,
  1. I’m not sure that there’s a video specifically on this topic, but it’s simple to implement:
a. Set your slicers to the value you want to return to
b. Create a bookmark called “clear slicers”
c. Add a button or image to your report and in the properties set the action to bookmark, and for the bookmark select the “clear slicers” bookmark you created in the previous step.
  1. This video should give you what you need:
https://portal.enterprisedna.co/courses/303649/lectures/27034321
I hope this is helpful.
– Brian
In regards to the last refresh video you referred me to, where/site do I copy the code from? as it is not included in the video for me to use.
thank you
Hello @arkiboys,
Below is the link provided from where you can copy the M Code.
Hoping this helps you. :slightly_smiling_face:
Note: In order to view the entire post, please click onto the link and not onto the expand/collapse button.
Thanks and Warm Regards,
Harsh
Thank you
