Requested clipboard operation did not succeed error
I am getting the below error while trying to copy data from tables in pbi.
Any idea why?
I suggest using the “Report this issue” button - when I Googled it, I got responses for SQL and clipboard - so I’m not sure this is just a PowerBi issue
My colleagues are also facing same issue, so its not anything to do with my laptop/memory I believe?
That’s why I suggested reaching out to Microsoft, include screenshots (even if they don’t seem necessary, it can help your question to get better attention). I’ve not seen this error before, so I’m not sure what exactly might be causing it, that’s why I turned to Google, and I didn’t see anything on teh first page of results that related this to PowerBi, PowerQuery, M code or DAX
Hi @Anu, did the response provided by @Heather help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query. Thanks!
Not really helped much, still not able to figure out the issue.
Hi @Anu
As suggested by Heather, Microsoft Power BI Support team will be help you as this is not a Power BI technical issue but tool related one. Power BI team will be able to check Traces and provide help.
Please raise request at
Ankit J
Hi @Anu, did the response provided by @Ankit help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query. Thanks!
Hi @Anu, we’ve noticed that no response has been received from you since the 11th of March. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @Anu, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
