Hi @Hemantsingh,
I’ve taken a small sample from your data, broke your logic up into individual steps for easy validation and extracted the results. Just copy this full script into a new blank query.
let
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("1VRbbsMwDLtLvj3AlOXXWYre/xpLSLlIgWXYx4Z2H6ICS5ZlhtbttvXsVkcpMBTf0tZS2bESnViIRgQxR3QyOhmdjE5GiWGewCwwC8wCs3DKeqWNMMtWzOIDdbun29Zyy4udRl6OrkdyYt2xExsRvN5Rk2wY0wC5LCc+IEIQjIgS5BXzq+0zTnaerP/l7MvJtZNrJ9fcRtTev+SvLtrmM39ndbUHTyN19t+50tl/Z/+d/Xfe1JhpzDRmGjONmcZMi/NZKfogB0cbx/3/ga4m7zZ45/qlrmaoDlwH1/FQ4/mFXa2/78v7iXIYqunsNHwspo/Gj2n+mAYQptyQ63JNTlWgKlAVxBDDk1Mx1VIpVVIh1fnZJHyRzrCz6LuNxfbVOwLhaYQNyrIHfvdcjQhiFr6BHSPBFyNtfZSgZow6bFruqL+unveXzZUdKvhYMsqLtDy3+/0T", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [DCItem = _t, #"202307" = _t, #"202308" = _t, #"202309" = _t, #"202310" = _t, #"202311" = _t, #"202312" = _t, #"202313" = _t, #"202314" = _t, #"202315" = _t, #"202316" = _t, #"202317" = _t, #"202318" = _t, #"202319" = _t, #"202320" = _t, #"202321" = _t, #"202322" = _t, #"202323" = _t, #"202324" = _t, #"202325" = _t, #"202326" = _t, #"202327" = _t, #"202328" = _t, #"202329" = _t, #"202330" = _t, #"202331" = _t, #"202332" = _t, #"202333" = _t, #"202334" = _t, #"202335" = _t, #"202336" = _t, #"202337" = _t, #"202338" = _t, #"202339" = _t, #"202340" = _t, #"202341" = _t, #"202342" = _t, #"202343" = _t, #"202344" = _t, #"202345" = _t, #"202346" = _t, #"202347" = _t, #"202348" = _t, #"202349" = _t, #"202350" = _t, #"202351" = _t, #"202352" = _t, #"202401" = _t, #"202402" = _t, #"202403" = _t, #"202404" = _t, #"202405" = _t, #"202406" = _t, #"Current Week to Shipment Receipt Week + 2" = _t, #"Actionable Range" = _t, #"Order Receipt Wk -1" = _t, #"TW Shipment Receipt + 2" = _t]),
ChType = Table.TransformColumnTypes(Source,{{"DCItem", type text}, {"Current Week to Shipment Receipt Week + 2", Int64.Type}, {"Actionable Range", Int64.Type}, {"Order Receipt Wk -1", Int64.Type}, {"TW Shipment Receipt + 2", Int64.Type}, {"202307", type number}, {"202308", type number}, {"202309", type number}, {"202310", type number}, {"202311", type number}, {"202312", type number}, {"202313", type number}, {"202314", type number}, {"202315", type number}, {"202316", type number}, {"202317", type number}, {"202318", type number}, {"202319", type number}, {"202320", type number}, {"202321", type number}, {"202322", type number}, {"202323", type number}, {"202324", type number}, {"202325", type number}, {"202326", type number}, {"202327", type number}, {"202328", type number}, {"202329", type number}, {"202330", type number}, {"202331", type number}, {"202332", type number}, {"202333", type number}, {"202334", type number}, {"202335", type number}, {"202336", type number}, {"202337", Int64.Type}, {"202338", Int64.Type}, {"202339", Int64.Type}, {"202340", Int64.Type}, {"202341", Int64.Type}, {"202342", Int64.Type}, {"202343", Int64.Type}, {"202344", Int64.Type}, {"202345", Int64.Type}, {"202346", Int64.Type}, {"202347", Int64.Type}, {"202348", Int64.Type}, {"202349", Int64.Type}, {"202350", Int64.Type}, {"202351", Int64.Type}, {"202352", Int64.Type}, {"202401", Int64.Type}, {"202402", Int64.Type}, {"202403", Int64.Type}, {"202404", Int64.Type}, {"202405", Int64.Type}, {"202406", Int64.Type}}),
AddRecord = Table.AddColumn(ChType, "temp", each
c = List.Buffer( List.LastN( Record.ToList( _ ), 4 )),
v = List.RemoveLastN( List.Skip( Record.ToList( _ ), 1 ), 4),
s = c{3} <= c{2},
r = List.Buffer( List.FirstN( List.Skip( v, c{0} ), c{1})),
#"Low Inv - Actionable Period" = if s then List.Count( List.Select( r, each _ <2 )) else "Item Setting Error",
#"High Inv - Actionable Period" = if s then List.Count( List.Select( r, each _ <10 )) else "Item Setting Error"
ExpandTemp = Table.ExpandRecordColumn(AddRecord, "temp", {"Low Inv - Actionable Period", "High Inv - Actionable Period"}, {"Low Inv - Actionable Period", "High Inv - Actionable Period"})
in
ExpandTemp
I hope this is helpful.
