To get the “Category” field as it is displayed in the Pivot table(sheet 5), i do a vlook in excel. With sheet 3, columns A, B with sheet 1. Vlookup Formula - =VLOOKUP(C4;Sheet3!A:B;2;0)
Excel sheet:https://drive.google.com/file/d/1RuGYLbC7zj0XR22cTdHRwNk6PPuAyqNW/view?usp=sharing
How do i replicate this in Powerbi?
Hi @Yrstruly , did the response provided by @DavieJoe help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query. Thanks!
Hi @Yrstruly , we’ve noticed that no response has been received from you since the 30th of March. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @Yrstruly, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
