I am having trouble with repeating dates. In Power BI for dates in the sales table it shows just the single day when looking at a visual, which is correct. When I bring in an excel file it shows the date multiple times.
I have different customer IDs that have all bought on the same day.
How do I keep the information but make it to where the dates aren’t repeating?
Hi @michael.gyure - I am not clear on the question, if you want to display data for single order and not combined/sum then you can drag the Order Id column in the visual and use Don’t Summarize for the Order Id if it’s a number. Or you can add Customer ID as per your requirement.
Once added, you will get same date repeated for Different Order Id/Customer ID in the visual.
IF this is not what you are looking for, then please explain the problem in bit more detail.
