Rename visual title as empty text
Hi @BrianJ ! I don’t remember where I saw your instructions on how to use an empty string inside the “Rename for this visual” option…can you share it here please?
I think I remember something to the effect of unicode U+2205…not sure tho.
Thanks in advance!
Hi @Schreg
You can use
https://unicode-explorer.com/c/180E#:~:text=The%20U%2B180E%20MONGOLIAN%20VOWEL,U%2B1821%20MONGOLIAN%20LETTER%20E.
On the link you have copy option :slight_smile:
