Removing unwanted Sales data
Hi
I’m having trouble removing some unwanted Sales data from my model. These unwanted transactions are giving me incorrect results in my visualisations.
I want to remove any Sales for a Customer that occur before the start of a monthly recurring gift for that customer.
For example, the customer below has five sales in the data occurring prior to the start of a new recurring payment that started on 01/04/2021.
I need to strip out those sales occurring prior to the pledge start date.
Pledges Sample 21-09-2023.pbix (26.6 KB)
SampleData 21-09-2023.xlsx (16.3 KB)
hello
a possible solution is by adding a additional column using the dax code
select =
CALCULATE (
VAR customer =
VALUES ( ‘Sample Data’[Customer ID] )
VAR soldDATE =
VALUES ( ‘Sample Data’[Sold Date] )
VAR pledgedate =
VALUES ( ‘Sample Data’[Pledge Start Date] )
MAXX (
FILTER ( ‘Sample Data’, [Customer ID] = customer && soldDATE < pledgedate ),
“do not select”
I add the pibx with the solution
there are of course other solution
regards
Roger
Pledges Sample 21-09-2023 possible solution.pbix (27.5 KB)
Hi Roger
Thank you for this solution.
I’ll test it later today.
Hi
Roger’s solution worked perfectly.
However, I was hoping not to bring the unwanted sales into my data model.
Would anyone know the M Code that would achieve the same result?
Johnatan
you can wrap it in a virtual table and filter the wanted data and hide the original sample table
see ( screen shot )
kind regards
roger
strong text
Jonathan
attached the solution in power query
kind regards
Roger
SampleData 21-09-2023 solution in Power Qury.xlsx (30.1 KB)
