Is there a way to remove the column header from the Matrix table. I have 2 attributes on the columns and the attribute name is coming as header in the first column. Is there a way to remove it. One way I found to rename the attribute as .(dot) but the user is able to see the dot.
I don’t believe so. If you remove it then your Months listed below will go away as well. Here is a similar Matrix I have in a model. If I remove the Prob of Close at the top, it also removes the Team, Job Count, Estimated Rev, Invoiced, etc… as well. Best option is to rename it or stick with the dot method you described.
