Hi there,
I created a KEY to match between fact table (orders) and dim table (geography). I attached sample in excel and PBI. I don’t get it why I can’t make it One to Many (1:*) - see below snapshot saying it’s an invalid relationship:
For instance, for this specific KEY 104MI Japan4010JP_MI_Japan I have 501 orders in my fact table:
Anyone here can help me getting this sorted? Thank you very much team.
Book1.xlsx (6.0 MB)
join issues.pbix (1.9 MB)
@SamSPAIN Geo Key in Geo Mapping Table isn’t a Primary key or a column with just unique values so Power BI can’t treat that column as Primary Key.
you’re absolutely correct - sorry my bad that I forgot to triple check… issue is that I wanted to keep a VERY granular dim table but then it was compromising the model.
It’s great to know that you are making progress with your query @SamSPAIN .
Please don’t forget if your question has been answered within the forum it is important to mark your thread as ‘solved’.
We request you to kindly take time to answer the Enterprise DNA Forum User Experience Survey, We hope you’ll give your insights on how we can further improve the Support forum. Thanks!
