Hi, I am having issues with the data refresh failing in the Power BI service. The error reads:
“Data source error: {“error”:{“code”:“DM_GWPipeline_Gateway_InvalidConnectionCredentials”,“pbi.error”:{“code”:“DM_GWPipeline_Gateway_InvalidConnectionCredentials”,“parameters”:{},“details”:[{“code”:“DM_ErrorDetailNameCode_UnderlyingErrorCode”,“detail”:{“type”:1,“value”:"-2147467259"}},{“code”:“DM_ErrorDetailNameCode_UnderlyingErrorMessage”,“detail”:{“type”:1,“value”:“The credentials provided for the SQL source are invalid. (Source at okr-bne-sql01\okr;OKR_REPORTS.)”}},{“code”:“DM_ErrorDetailNameCode_UnderlyingHResult”,“detail”:{“type”:1,“value”:"-2147467259"}},{“code”:“Microsoft.Data.Mashup.CredentialError.DataSourceKind”,“detail”:{“type”:1,“value”:“SQL”}},{“code”:“Microsoft.Data.Mashup.CredentialError.DataSourcePath”,“detail”:{“type”:1,“value”:“OKR-BNE-SQL01\OKR;OKR_REPORTS”}},{“code”:“Microsoft.Data.Mashup.CredentialError.Reason”,“detail”:{“type”:1,“value”:“AccessUnauthorized”}},{“code”:“Microsoft.Data.Mashup.MashupSecurityException.DataSources”,“detail”:{“type”:1,“value”:"[{“kind”:“SQL”,“path”:“OKR-BNE-SQL01\OKR;OKR_REPORTS”}]"}},{“code”:“Microsoft.Data.Mashup.MashupSecurityException.Reason”,“detail”:{“type”:1,“value”:“AccessUnauthorized”}}],“exceptionCulprit”:1}}} Table: C2W Client Offer. Cluster URI:WABI-AUSTRALIA-EAST-A-PRIMARY-redirect.analysis.windows.net Activity ID: c6af95ec-c6a7-4aed-ac39-348682e0ca1a Request ID: d99ed5ba-f539-a61a-e530-ed737a34d771 Time: 2022-08-14 23:21:23Z”
The on-premises data gateway uses the default service account and the password has expired, as seen in the command prompt screenshot:
If I reset the service account password and log in again, do I still need to re-configure the gateway settings in Power BI service or it would automatically update? Or is this related to service password expiration or we need to provide a different account for the gateway?
Thank you! Would really appreciate all your inputs and suggestions!
