RE: Allocating Results To Templates At Every Single Row
Hi All -
I’ve tried using Sam’s method to allocate results at every single row to a specified template which i had created.
This is the template which i had used, similar to the one shown on Sam’s video.
Currently, my dashboard will only show the format which i want if i include the index column which had been sorted in ascending order.
Capture1
My end goal is to have a dashboard in the format i had defined, without the index columns similar to the model in Sam’s video tutorial.
Any help is greatly appreciated. Thanks!
You do have to add the index column, but then you just hide it within the table. Just minimize that column.
I believe I do showcase this in the course a few times.
