RankX practice model
Can you suggest videos and practice model I can watch and practice on to learn advance Rankx function. Including ordering, ties and dense. I have quite a few duplicated values in the rankx column and also need the RANKx values to change as the slicer selection changes. RankX column can have duplicated rank but not skip rank numbers. For example 1, 2,2,2 ,3,4,5,6 (not 1,3,4). Also wanting to use a variable. thank you inadvance.
@ElizabethTachjian ,
Here are two videos, one by me and one by @AntrikshSharma that should fit the bill for you. We take different approaches so you’ve got some options in how you handle this problem:
I hope this is helpful.
– Brian
Hi @ElizabethTachjian
Here is another approach to break RANKX ties. I hope this is also helpful to you.
Thank you for coming to the rescue. I look forward to the learning the Rankx function. Cheers E
