RANKX example 3 in Mastering DAX Calculations course
Hi All,
I am working through the Mastering DAX calculations course and have hit a problem with one of the ranking formulas in the ‘Practical examples for using ranking functions’ video.
There’s an example in which a formula ranks the total sales for the Customer Names/Product Names combination. Here is the formula:
RANKX Example 3 =
RANKX(
CROSSJOIN( ALL( Customers[Customer Names] ), ALL( Products[Product Name] ) ),
[Total Sales], ,DESC )
As you can see from the screen shot, the function hasn’t calculated the ranks correctly…
Rankx
What have I missed?
Thanks in anticipation,
Pete.
Looks correct to me, Product 1 at 82K is ranked 1 for Lorens, Product 1 at 62K is Ranked 2 for Dharma
Hi @AntrikshSharma,
Thanks for the quick reply…This is what the expected results should be (taken from the video)…
Cheers,
Pete.
@pete962 That’s strange, just checked the video and your measure is exactly the same, maybe the difference is in the Total Sales Measure? Can you share the PBIX file?
Hello @pete962,
Well the same logic and formula absolutely works fine in my file. Below is the screenshot provided for the reference -
Below are the formulas used that I’ve used to calculate the Ranking as was shown in the video -
Total Sales =
SUMX( Sales ,
    Sales[Order Quantity] * Sales[Unit Price] )
RANKX - Harsh =
RANKX(
    CROSSJOIN( ALL( Customers[Customer Names] ) , ALL( Products[Product Name] ) ) ,
[Total Sales] , , DESC )
I’m also attaching working of my PBIX file for the reference.
Hoping you find this useful and helps you to find the desired results that you’re looking for. :slightly_smiling_face:
Thanks and Warm Regards,
Harsh
RANKX Function.pbix (661.5 KB)
Hi @Harsh and @AntrikshSharma,
Thanks for the suggestion and. @Harsh, I have copied your formula and pasted it into my PBI and still the same results…I have uploaded a copy of the problematic PBIX…
Thanks,
Pete.Mastering DAX Calculations.pbix (827.7 KB)
@pete962 To me it looks like that the PBI file is broken, look at the below screenshot, it is not able to rank even the products.
But when I created a new file it works correctly with single column with ALL.
Thanks for this @AntrikshSharma, do you know if this is a common fault in a PBIX? Thanks for investigating this and confirming that I’m not going crazy :smiley:
Cheers,
Pete.
I’ve never seen this happen before. Great detective work by @AntrikshSharma in diagnosing the source of the problem.
@pete962 To be honest, I don’t really know.
This works in your file :
RANKX Example 3 =
RANKX ( ALL ( Products ), [Total Sales],, DESC )
This doesn’t (This made me question my DAX knowledge):
RANKX Example 3 =
RANKX ( ALL ( Products[Product Name] ), [Total Sales],, DESC )
I am able to rank in the table:
When I created a duplicate product table, everything works, I even duplicated the calculated columns:
So it will be safe to assume that something went south when you imported the data from the queries:
here is the working file:
Mastering DAX Calculations.pbix (834.9 KB)
I’ve never seen it happen before either …
Thanks @AntrikshSharma for your investigations and solution :smiley:
