Ranking (Breaking Ties) for a Category based on a Measure with duplicate values for categories
Hi Guys,
Here is the scenario . I have a category column and a measure which is simply the count of rows for the table. Now i need to rank the categories of that table based on the count measure. Thing is there are a lot of categories for which the count is tied or same.
First i need to break the ties so that rank can be given in ordinal/continuous fashion like 1,2,3,4,5 without any repetition of rank.
Solution which I have tried are also in the pbix. For heads up i have tried break the ties using median and also tried to break the ties with rand and randbetween.Rank With Ties issue.pbix (66.4 KB)
Attaching the sample PBIX for everyone.
@Greg @quantumudit @Harsh @AntrikshSharma. Tagging you guys as i need it a little urgently.
best regards,
Hemant
@Hemantsingh,
I actually did a video on this exact topic earlier this summer:
Hope this is helpful.
Hi @Hemantsingh. Took a quick look … I can’t see a way forward without additional info. As per @BrianJ’s post, I think you’ll need to have rules defined for tiebreaking (i.e., multiple rankings); RAND() in my experience has never been accepted by the client as a “rule”. Good luck. Greg
@Hemantsingh,
Even if RAND were an acceptable tiebreaker, be really careful – RAND behaves very oddly in DAX and PQ, and my experience is that you throw that into the mix with RANKX, it can generate some really weird results.
@Hemantsingh Try this:
Alphabetical Rank =
IF (
    ISINSCOPE ( 'Sheet 1'[Step] ),
    VAR CurrentStep =
        SELECTEDVALUE ( 'Sheet 1'[Step] )
    VAR Result =
        COUNTROWS (
            FILTER (
                ALL ( 'Sheet 1'[Step] ),
                'Sheet 1'[Step] >= CurrentStep
        Result
Ranking =
IF (
    RANKX (
        [Total Reject] + DIVIDE ( [Alphabetical Rank], 100 ),
        DESC,
        SKIP
Hey @AntrikshSharma,
Once again you have come up with a solution that has its roots in excel, simple and easy. I didn’t know that alphabetical ranking is also possible. Your excel roots are really paying off.
Thanks for helping out.
@BrianJ @Greg Thanks for putting in the effort on request and responding at earliest.
Best Regards,
Hemant
