I’m facing an issue with displaying correct data that would meet given conditions.
Working with data from Azure Devops data source with task to present Scrum hierarchy on gantt chart timeline
I’ve managed to expand the parent >> child relations into conditional columns, one for each different work item types, but now facing issue with multiple data available for the highest level of parent as it fetches everything from drill down to lowest hierarchy level.
The best example is to focus on Level 1 of hierarchy named “Dashboard”.
It is an Epic work item type and I would like to create a measure that would lookup for a data where it meets this criteria, so would only result in one applicable created and changed dates. Currently it shows data for every other work item type.
Measure then should do the same for next level of hierarchy with work item type of “Feature”, and so on to the level 1.
I’m aware of both points you’ve mentioned.
I’ve filtered workitem type for Epic and Feature on purpose to showcase what result I’m looking for.
So that Lev 1 column “Dashboard” with condition of workitem type of “Epic” will give me only one row of data, and then going to level 2 “Discovery”, “Development” etc. will give me data for condition of workitem of “Feature” and so on till level 4.
Hi @DanDer - Based on my understanding of requirement, it is not possible in a Table visual but in a Matrix visual. Also, workitem will be part of Column instead of Row.
Have created below measure for Changed Date and similarly one for Create Date. Check if it is helpful.
Hello @DanDer, we noticed no response from you since November 26.
Did the responses above help you with your inquiry?
