R, with its extensive package ecosystem and powerful analytical capabilities, stands as a pillar in the data analytics world. Dive into this workout to sharpen your R skills and elevate your data analysis prowess.
Scenario:
Imagine you’re a data scientist analyzing customer feedback for a product launch. You have a dataset with customer demographics and their satisfaction scores. How would you leverage R to extract insights and understand key drivers of customer satisfaction?
Objectives:
By the end of this workout, you should be able to:
Load and inspect data in R.
Conduct basic data wrangling and transformation using R.
Perform exploratory data analysis (EDA) to glean insights.
Interactive Task:
Given your understanding of R, answer the following:
You have a CSV file named “customer_feedback.csv”. How would you load this dataset into an R dataframe named “feedback_df”?
- Your Code: ________________________
If you want to get a quick summary of each column in “feedback_df”, which function would you use?
To visualize the distribution of satisfaction scores, which type of plot would you consider, and how might you code it in R?
Your Answer: ________________________
Questions:
In R, which package is widely recognized for its data wrangling capabilities, offering functions like
mutate()
,select()
, andfilter()
i) ggplot2
ii) shiny
iii) dplyr
iv) lattice
When dealing with missing data in an R dataframe, which function can be used to remove any rows that contain NA values?
i) drop_na()
ii) remove_na()
iii) na.omit()
iv) exclude_na()
Duration: 20 minutes
Difficulty: Intermediate
Period
This workout will be released on Tuesday, September 5, 2023, and will end on Thursday, September 28, 2023. But you can always come back to any of the workouts and solve them.
