Hi
I would like to know how to run powerBi , R script using the R instance in Amazon Web Server
Is this possible
Hi
Is this possible
I’m certainly not a R whiz, but hopefully theses links point you in the right direction.
https://mran.revolutionanalytics.com/download
https://community.powerbi.com/t5/R-Script-Showcase/bd-p/RVisuals
Cheers
Adam
This is a super interesting question. I’m not sure whether it’s possible or not, but will be glad to dive into this question this evening after work. In the meantime, I’m looping in Enterprise DNA Poweruser @bradsmith who may know the answer offhand.
Ohhh boy… I would need to know exactly how you’d like to use the R instance in AWS. I’m assuming you’re referring to an Amazon EC2 R instance? Are you hoping to import the data, use a direct query, or include it in a visual?
Edit - Here’s the recommended configuration:
It would be interesting to hear more about your use case and what you’re trying to accomplish, to see whether a simpler solution like R Studio Cloud might be workable.
– Brian
Hi @gbortz27, we’ve noticed that no response has been received from you since the 17th of February. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @gbortz27, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
