Hello Community,
I plotted a radar plot using vega to interact in power bi. However, even though I am using pbiNominal
as a way to fetch the pbi theme colors. If I use the another pbi visual the with same chart variables they do not match. See below:
Here you can see that in the radar plot it fetches green and blue (the first two colors in my theme), however, the line chart assigns the colors based on the values in the categorical field.
Is there a way to match them?
you can find my code below. I did not attach my pbi file because the answer is either simple, or not possible. If you still require it let me know and I’ll attach a WIP since this has confidential data.
Kind regards,
Miguel
"width": 450,
"height": 400,
"padding": {
"left": 100,
"top": 100,
"bottom": 100
"autosize": {"type": "none", "contains": "padding"},
"signals": [
{"name": "radius", "update": "(width / 2)-40"}
"data": [
"name": "dataset"},
"name": "keys",
"source": "dataset",
"transform": [
"type": "aggregate",
"groupby": ["key", "average_intensity"]
"scales": [
"name": "angular",
"type": "point",
"range": {"signal": "[PI, -PI]"},
"padding": 0.5,
"domain": {
"data": "dataset",
"field": "key",
"sort": {"op": "average", "field":"value"}
"name": "radial",
"type": "linear",
"range": {"signal": "[0, radius]"},
"zero": true,
"nice": false,
"domain": {
"data": "dataset",
"field": "value"
"domainMin": 0
"name": "color",
"type": "ordinal",
"domain": {
"data": "dataset",
"field": "category"
"range": {"scheme": "pbiColorNominal"}
"axes": [
"orient": "top",
"scale": "radial",
"domainWidth": 0.2,
"tickCount": 4,
"tickWidth": 0.2,
"labelFlush": false,
"labelFontSize": 9,
"labelColor": "gray"
"encode": {
"enter": {
"x": {"signal": "radius"},
"y": {"signal": "radius"}
"marks": [
"type": "group",
"name": "categories",
"zindex": 1,
"from": {
"facet": {
"data": "dataset",
"name": "facet",
"groupby": ["category"]}
"marks": [
"type": "line",
"name": "category-line",
"from": {"data": "facet"},
"sort": {"field": "datum.average_intensity"},
"encode": {
"enter": {
"interpolate": {"value": "linear-closed"},
"x": {"signal": "scale('radial', datum.value__highlight) * cos(scale('angular', datum.key))"},
"y": {"signal": "scale('radial', datum.value__highlight) * sin(scale('angular', datum.key))"},
"stroke": {"scale": "color", "field": "category"},
"strokeWidth": {"value": 1},
"fill": {"scale": "color", "field": "category"},
"fillOpacity": {"value": 0.2}
"type": "line",
"name": "category-line-highlighted",
"encode": {
"enter": {
"fill": [
"test": "datum.__selected__ == 'on'",
"scale": "color",
"field": "category",
"value": 0
"type": "symbol",
"name": "symbol-category",
"encode": {
"enter": {
"x": {"signal": "scale('radial', datum.value) * cos(scale('angular', datum.key))"},
"y": {"signal": "scale('radial', datum.value) * sin(scale('angular', datum.key))"},
"fillOpacity": {"value": 0.5},
"size": {"value": 30}
"type": "text",
"name": "value-text",
"from": {"data": "category-line"},
"encode": {
"enter": {
"x": {"signal": "datum.x"},
"y": {"signal": "datum.y"},
"text": {"signal": "datum.datum.value"},
"align": {"value": "center"},
"baseline": {"value": "middle"},
"fill": {"value": "black"},
"fillOpacity": { "value": 0}
"type": "rule",
"name": "radial-grid",
"from": {"data": "keys"},
"zindex": 0,
"encode": {
"enter": {
"x": {"value": 0},
"y": {"value": 0},
"x2": {"signal": "radius * cos(scale('angular', datum.key))"},
"y2": {"signal": "radius * sin(scale('angular', datum.key))"},
"stroke": {"value": "lightgray"},
"strokeWidth": {"value": 0.5}
"type": "text",
"name": "key-label",
"zindex": 1,
"encode": {
"enter": {
"x": {"signal": "(radius + 15) * cos(scale('angular', datum.key))"},
"y": {"signal": "(radius + 15) * sin(scale('angular', datum.key))"},
"text":{"signal": "datum.key"},
"align": [
"test": "abs(scale('angular', datum.key)) > PI / 2",
"value": "right"
"value": "left"
"baseline": [
"test": "scale('angular', datum.key) > 0", "value": "top"
"test": "scale('angular', datum.key) == 0", "value": "middle"
"value": "bottom"
"fontWeight": {"value": "bold"},
"dx": {"value": 0},
"dy": {"value": -10},
"limit":{"signal": "40"},
"lineBreak": {"value": "_"}
"type": "line",
"name": "outer-line",
"from": {"data": "radial-grid"},
"sort": {"field": "datum.datum.average_intensity"},
"encode": {
"enter": {
"x": {"field": "x2"},
"y": {"field": "y2"},
"legends": [
"orient": "none",
"legendX": -200,
"legendY": -200,
"fill": "color",
"direction":"horizontal"
