When I downloaded the new external tools installer available from https://enterprisedna.co/external-tools the file was not installable on my windows 10 PC.
I had to change the file extension to an msi file so I could install it.
After doing that it did install correctly!
Thank you for sharing this @darandavis!
@EnterpriseDNA Is there another level of membership that accesses the external tool? In my attempts to log in and download the tool, I am redirected to https://portal.enterprisedna.co/
Thanks for your help.
Once you are at the link you posted, click on the Resources button you will see a section for External Power Tools, you will find the download there.
Hello @Naate hope the answer from @DavieJoe helped your query.
Here is the direct link for the External Power Tools for your convenience.
Please don’t forget if your question has been answered within the forum it is important to mark your thread as ‘solved’.
We request you to kindly take time to answer the Enterprise DNA Forum User Experience Survey,We hope you’ll give your insights on how we can further improve the Support forum. Thanks!
I was more posting this to help others so what I posted was a workaround to the problem which does work. To me the solution is to fix the download so it is an msi type file so it will directly install on a windows machine. It is possible the file type is wrong on the edna platform or the teachable platform is changing the file type when it is downloaded.
@DavieJoe post was for @Naate question about finding the download.
Hey @darandavis it was for @Naate, I mean to tag him but my fingers & brain went on strike!
Sorry about the confusion @darandavis, the response I sent was also for @Naate
Anyways, closing this thread now. Again, thank you for this solution
