Hello. Since SVG visuals are huge codes, I’d like to know their impact on performance on big dashboards, in order to know if they are actually worth it on real life scenarios.
Thx in advance
Thx in advance
would you be able to compare the performance with Dax Studio or Tabular Editor? I’m not sure which one has the capabilities
Hmm, not sure. I was wondering if someone already did theese tests or used svgs on real life projects
it likely depends on the model you are using. i’m sure Microsoft likely test it out on their test data. Did you contact Microsoft and asked the question?
I didn’t even know I could do this xD
of course you can asked the microsoft community.
