Since on VS Code we need to create a sample dataset instead of using the default “name”:"dataset function, is there an easy way to extract the columns we need to create a sample vega-lite dataset for use on VS Code?
Thanks in advance
Thanks in advance
Not that I’ve found … the sample datasets that I use in VSC have all been manually created (and are thus simple/minimal).
