Not really looked into this much yet, but thought I would start a post on this subject anyway.
A new feature that allows you to determine what Power Query is doing behind the scenes.
Find slowdowns and background events etc.
Microsoft will be expanding on this feature in the future.
Hi @marcster_uk, we’ve noticed that no response has been received from you since the 27th of March. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
