Hi everyone,
I hope someone have done this one before and can share their knowledge.
I am trying to Run a Query against a Dataset and then Add those rows to Excel Online. Does anybody have a flow they could share?
I have an existing Excel table online on Sharepoint. And I want to populate that table with Power bi data. I already tried these steps: Recurrence trigger â Run a query against a dataset ->Add A row into a Table and used this expression: item()?[âXXXXXXX[xxxxxx]â]
We aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
Hi @Jetuke_ES, we noticed that you have not responded to our request above. We are waiting for the masked demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details. In case there wonât be any activity on it in the next few days, weâll be tagging this post as Solved.
Have you tried âAnalyze in Excelâ option instead. You can set up a Power Automate flow to refresh this Excel file and append the data from the refreshed table of this Excel file to a master Excel file.
that might be a good idea! i will definitely try that I used Office script to delete the data on a Sunday and then i need to add just new data into the excel. For the option you mention, i wouldnt need to query power bi?
You can connect to Power BI datasets in Excel by starting in the Power BI service or in Excel for the web or the Excel desktop app. You will be querying Power BI Service using Connect to Power BI Dataset connector.
Think iâll need to find another way as i need it in a table, not pivotTable. Iâm trying to make it ânormalâ table look in pivot but no success completely yet. Thank you so much for your help! i just wonder if maybe you have parsed json to get the data?
