Python Workout 016 - Dive into Basic Plotting with Matplotlib
Title: Python Proficiency: Dive into Basic Plotting with Matplotlib
Description:
Matplotlib is Python’s premier library for creating static, animated, and interactive visualizations. In this workout, grasp the essentials of crafting simple plots and kickstart your data visualization journey with Python.
Scenario:
Imagine you’ve been given a series of data points representing monthly sales figures for a year. Using Matplotlib, how would you visually represent this data to discern patterns and trends?
Objectives:
By the end of this workout, you should be able to:
  1. Set up and customize basic plots using Matplotlib.
  2. Understand the anatomy of a Matplotlib plot.
  3. Visualize data effectively to convey insights.
Interactive Task:
Given your understanding of Matplotlib, answer the following:
  1. If you want to create a line plot to visualize the sales trend over months, which Matplotlib function would you start with?
    • Your Answer: ________________________
  2. How would you add a title to your plot, say “Monthly Sales for 2023”?
  3. To save your plot as an image file, say “sales_plot.png”, which function would you use?
Questions:
  1. In Matplotlib, which function is commonly used to show the plot after it has been defined?
    • i) display()
    • ii) visualize()
    • iii) plot()
    • iv) show()
  2. If you want to create a scatter plot instead of a line plot, which Matplotlib function would you use?
    • i) scatter()
    • ii) point()
    • iii) dot()
    • iv) spread()
Duration: 20 minutes
Difficulty: Beginner
Period :
This workout will be released on Wednesday, September 20, 2023, and will end on Thursday, October 05, 2023. But you can always come back to any of the workouts and solve them.
Hi @EnterpriseDNA ,
Here is my solution to this workout:
Interactive Task:
Answer:
import matplotlib.pyplot as plt
Sample data representing monthly sales figures
months = [‘Jan’, ‘Feb’, ‘Mar’, ‘Apr’, ‘May’, ‘Jun’, ‘Jul’, ‘Aug’, ‘Sep’, ‘Oct’, ‘Nov’, ‘Dec’]
sales = [10000, 12000, 11000, 13000, 14000, 16000, 18000, 17000, 19000, 21000, 22000, 24000]
Create a line plot
plt.figure(figsize=(10, 6)) # Adjust the figure size as needed
plt.plot(months, sales, marker=‘o’, linestyle=‘-’)
plt.title(‘Sales Trend Over Months’)
plt.xlabel(‘Month’)
plt.ylabel(‘Sales Amount’)
plt.grid(True)
Show the plot
plt.show()
  1. How would you add a title to your plot, say “Monthly Sales for 2023”?
Answer:
Create a line plot
Add a title to the plot
plt.title(‘Monthly Sales for 2023’)
plt.xlabel(‘Month’)
plt.grid(True)
Show the plot
plt.show()
  1. To save your plot as an image file, say “sales_plot.png”, which function would you use?
Answer:
Save the plot as an image file (PNG format)
plt.savefig(‘sales_plot.png’)
Questions:
Answer:
  • iv) show()
  1. If you want to create a scatter plot instead of a line plot, which Matplotlib function would you use?
Answer:
  • i) scatter()
Thanks for the workout.
Keith
Answer:
Interactive Task
  1. plot()
  2. ax.set_title(“Monthly Sales for 2023”)
  3. fig.savefig(‘sales_plot.png’, dpi=200, orientation=‘landscape’)
  1. iii) show()
  2. i) scatter()
Objective
Monthly Sales Visualization Script
Author: Udit Kumar Chatterjee
Email: quantumudit@gmail.com
This script creates a visual representation of monthly sales data for the year 2023.
It uses Matplotlib to generate a line plot of sales figures for each month and applies
the 'Cyberpunk' style for a unique visual effect. Sales data is provided in thousands of
US dollars (USD) and is formatted with tick labels displaying the values in thousands
with a '$' sign (e.g., "$35K"). The resulting plot is customized with titles, labels,
and axis limits for clarity. Additionally, a gradient fill is added to enhance the visual impact.
# Import necessary libraries
import mplcyberpunk
from matplotlib.ticker import FormatStrFormatter
# List of months and corresponding sales numbers (in thousands USD)
months = ["Jan", "Feb", "Mar", "Apr", "May", "Jun",
          "Jul", "Aug", "Sep", "Oct", "Nov", "Dec"]
sales = [25, 35, 32, 40, 38, 37, 48, 43, 34, 41, 45, 42]
# Apply the Cyberpunk style
plt.style.use("cyberpunk")
# Create a figure and axis
fig = plt.figure(figsize=(8, 5))
ax = fig.add_subplot()
# Plot
ax.plot(months, sales, marker="o")
# Create a FormatStrFormatter for Y-axis labels
tick_fmt = FormatStrFormatter("$%dK")
ax.yaxis.set_major_formatter(tick_fmt)
# Customize the plot
ax.set_title("Monthly Sales Trend - 2023", pad=15, fontweight="heavy")
ax.set_xlabel("Months", labelpad=15, loc="center", fontweight="bold")
ax.set_ylabel("Sales", labelpad=15, loc="center", fontweight="bold")
ax.set_ylim(20, 50)
# Add a gradient fill to the plot
mplcyberpunk.add_gradient_fill(alpha_gradientglow=0.5)
# Save the figure
fig.savefig('./sales_trend_2023.png', dpi=200, orientation='landscape')
