I’m following Enterprise DNA seasonal decompose for powerBi tutorial and I’m stuck at power query section.
When I input the code in power query it gives me back this message ![]()
“DataSource.Error: ADO.NET: Python script error.
pandas._libs.tslibs.parsing.DateParseError: Unknown datetime string format, unable to parse: Microsoft.OleDb.Date, at position 0”
Seems to me that it is processing also the header but it can’t read it as date string.
I don’t know how to fix this, do you have any suggestion?
*** READ FIRST ***
Before you send your question.
Make sure that all details relevant to your question is complete:
- Your current work-in-progress PBIX file - VERY IMPORTANT
- A clear explanation of the problem you are experiencing
- A mockup of the results you want to achieve
- Your underlying data file
Also make sure that your data file contains no confidential information. If it does, click the link above.
*** DELETE THIS MESSAGE IF YOU ARE SURE ALL YOUR DETAILS ARE COMPLETE OR IF THE ABOVE INFORMATION IS NOT APPLICABLE TO YOUR QUESTION.***
