I have published an power bi report and have gone to settings- dataset- Q&A and have turned on the Q&A feature. When I go to the report, I don’t see the Q&A bar anywhere and can’t find how to make it showup. See the attached image for settings place.
What am I missing?
You can use the Q&A feature on dashboard only, and here you have mentioned about “report”.
Hi @stiefel.ed, did the response provided by @amira.bedhiafi.pro help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark the thread as solved. Thanks!
Hi @stiefel.ed, we’ve noticed that no response has been received from you since the 21st of January. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
You are right! Thank you. I have a follow up questions. When I pin a page live to a dashboard, it says “click to follow link” for page navigation, but it does not navigate anywhere. It only works in the report. Ideas?
I apologize for not responding to this. I had moved on to a lot of other work and had my report offline so I had forgotten to circle back.
You are welcome
Do you happen to know the answer to my questions about why the dashboard won’t let me navigate between the page links?
Can you give me the link of the question?
It is in this conversation as a follow-up in my initial reply to your response:
When I post a report to a dashboard, it says “Click to follow link” but the page navigation buttons I have built into the report don’t work in the Dashbaord.
Can you attach a screenshot or just answer this question by saying if the tile contains a live report page/table/other single visual?
I am not sure. I went to the repot online and posted to the dashboard. I didn’t see an option to post the live report, page, table, or single visual. It shoes whatever page I was on when I wen to post it to a dashboard. I want the full functionality of the report (navigating pages) while also using the QA function from dashboard.
