hello,
in the power bi desktop I have set the date format to be short, i.e. 14/02/2024
And so in the desktop I see the date formatted as mentioned.
Then after publishing I see the date columns displaying as 02/14/2024
Any suggestions?
Thank you
Hi @arkiboys ,
Did you set your format in desktop or it is automatically set as you want ?
I have situation with the numbers. In Desktop it shows in format as expected.
After publishing using different Web browser we saw it different formats.
To be precise - we need to go and format each measure separate.
Good luck
