Hi all,
I have followed this video from Enterprise DNA, https://youtu.be/jclWnA7pEvY , on how to compute prior week sales. But for some reason my output is not correct. Below is the DAX formula and the output and I have attached a WIP file. Thank you for your help.
WIP File.pbix (11.0 MB)
Hello @ysherriff . I have done the same thing at my current job to show the number of active oil rigs in the country but needed to show the previous week only. See my DAX code below. Then in your date table make sure you have a column called IsLastWeek (Y or N). Use SumX and not CountX
Thanks Phil but I have to use CountX because my fact table are non-numerical. They are texts.
I will update the formula and see what the results are and get back to you.
Is this not what you are needing?
Paul
Phil, What is the formula to create an IsLastWeek Column?
Thank you
I get this error message when I change it from Countx to SumX.
My fact table are text based.
strange. I used the file you attached to get the results I showed.
IsLastWeek =
var vLastWeek = CALCULATE(MAX (‘DATE’[WEEK & YEAR]),
FILTER(ALL(‘DATE’), ‘Date’[Date] = TODAY()-6))
IF(‘Date’[Week & Year] = vLastWeek, “Y”, “N”)
Can you upload the file Paul? Let me check something
Thank you
I must have a space or something in my formula but it works. Thanks for your help.
@ysherriff Is it working for you now? There is a great date query here on the forum I would recommend.
Yes and thank you. Can you point me to the resource Paul?
