I just want to aks if anyone has any expereince working with Primavera P6 (Project Control Software) and connecting it with Power BI Desktop
I have been trying to connect and create reports of project updates and Earned Value Management and most importantly create automation for any updates in the project should be reflected in Power BI Reports
Hi @anonymous210 ! We specialise in creating custom Power BI connectors. For many businesses, extracting data from an API to Power BI can be tricky. Fortunately, our custom Power BI connectors make it easy with .mez files used to locate data sources inside Power BI desktop.
We would love to discuss this and help you to solve it
We have noticed that your inquiry has remained unresolved for an extended period of time, indicating that it may have been outside the capabilities of our experts and users.
If you believe that you have provided all the necessary context for your concerns and have familiarized yourself with effective forum usage by referring to this guide, we recommend exploring the additional resources included with your subscription. These resources can provide valuable assistance with your Power BI education, and we encourage you to utilize them.
While our users and experts strive to assist with inquiries to the best of their abilities, it is important to acknowledge that not all concerns can be addressed, particularly when there are valuable learning opportunities involved. Thank you for your understanding.
We sincerely hope that you find the solution you are seeking and achieve your desired outcome.
However, if your P6 DB (or OPC DB) is on Oracle Hosting (or any hosted environment), you will need to extract the data with an interface. Check out www.p6etl.com - or contact me at pciszewski@MustangTechnologies.com
