Hello @Cedric,
In order to achieve the solution based on the scenario that you’ve mentioned. Below are the measures alongwith the screenshot of the final results provided for the reference -
1. Opening Inventaire =
----- Calculation of Opening Inventory Ever -----
VAR _First_Inventory_Date_Ever =
CALCULATE( MIN( Tout[Date calculé pour rapport inventaire] ) ,
REMOVEFILTERS( ) )
VAR _Min_Date =
MIN( Dates[Date] )
VAR _Max_Balance_Date =
CALCULATETABLE(
ADDCOLUMNS(
SUMMARIZE(
Tout ,
Tout[Type du produit] ) ,
"@Max_Balance_Date" ,
CALCULATE( MAX( Tout[Date calculé pour rapport inventaire] ) ) ) ,
Dates[Date] <= _Min_Date ,
Tout[Type du produit] = "Inventaire" )
VAR _Max_Balance_Dates_With_Lineage =
TREATAS(
_Max_Balance_Date ,
Tout[Type du produit] ,
Dates[Date] )
VAR _Opening_Inventory_Ever =
CALCULATE( SUM( Tout[Quantité calculé pour inventaire] ) ,
_Max_Balance_Dates_With_Lineage )
----- Calculation of Previous Month Cumulative Entrant -----
VAR _Previous_Month_Cumulative_Entrant =
DATEADD( Dates[Date] , -1 , MONTH ) ,
Tout[Type du produit] = "Entrant" ) ,
FILTER( ALLSELECTED( Dates[Date] ) ,
Dates[Date] <= MAX( Dates[Date] ) ) )
VAR _Previous_Month_Cumulative_Sortant =
Tout[Type du produit] = "Sortant" ) ,
----- Calculation of Final Results -----
VAR _Results =
SWITCH( TRUE() ,
ISINSCOPE( Dates[MM-YYYY] ) && _First_Inventory_Date_Ever = _Min_Date , _Opening_Inventory_Ever ,
ISINSCOPE( Dates[MM-YYYY] ) , _Opening_Inventory_Ever + _Previous_Month_Cumulative_Entrant + _Previous_Month_Cumulative_Sortant )
_Results
2. Entrant =
IF(
KEEPFILTERS( Tout[Type du produit] = "Entrant" ) ) )
3. Sortant =
IF(
KEEPFILTERS( Tout[Type du produit] = "Sortant" ) ) )
4. Closing Inventaire =
VAR _Min_Date =
MIN( Dates[Date] )
CALCULATETABLE(
ADDCOLUMNS(
SUMMARIZE(
Tout ,
TREATAS(
_Max_Balance_Date ,
Dates[Date] )
----- Calculation of Cumulative Entrant -----
VAR _Cumulative_Entrant =
Tout[Type du produit] = "Entrant" ,
----- Calculation of Cumulative Sortant -----
VAR _Cumulative_Sortant =
Tout[Type du produit] = "Sortant" ,
----- Calculation of Results -----
VAR _Results =
IF(
_Opening_Inventory_Ever + _Cumulative_Entrant + _Cumulative_Sortant )
_Results
Hoping you find this helpful and meets your requirements that you’ve been looking for.
Thanks and Warm Regards,
Harsh
Inventory Calculation - Harsh.pbix (236.4 KB)
