Automated Data Cleansing Pipeline
Project Description:
Create an automated data cleansing pipeline using Power Query in Excel or Power BI. This project will focus on automating the process of cleaning and transforming a raw data file into a structured, analysis-ready format.
Use the below dataset.
Automated_Data_Cleansing_Pipeline_Dataset.csv (13.3 KB)
Tasks:
- Import the raw data file into Power Query.
- Apply transformations to clean the data, including removing duplicates, correcting errors, and standardizing data formats.
- Merge and append data from multiple sources to enrich the dataset.
- Document each step of the transformation with detailed annotations.
Expected Outcome:
A Power Query script that automates the entire data cleansing process, complete with documentation for each step to explain the transformations performed.
Level:
Beginner
