Hoping to get some help in Power query - Dataflows
I am connecting to an Excel file in Sharepoint with multiple tabs.
The current configuration of Transformation steps allows the tab name to be always the same name to pick the correct tab as shown below screenshot Item = Data May 2024 ( Excel tab name)
Is there a way to make it dynamic/wildcard like item = Data%
I cannot get a resource to understand whether it is possible.
Can anyone have a similar situation? Can you advise if this is possible?
Using the Datamentor “Code Explainer” built within EDNA platform.
this what comes up:
# Code Explanation
The provided code snippet is written in M Language, commonly used in Power Query within Excel and Power BI for data transformation tasks.
## Code Breakdown
### 1. `Source` Step
```m
Source = Excel.Workbook(#"Parameter (2)", null, true)
Purpose: Reads data from an Excel workbook.
Function: Excel.Workbook function is used to import data.
#"Parameter (2)": Refers to the specific Excel file or parameter that contains the workbook data.
null: This indicates that no particular encoding is specified.
true: Indicates that the function should try to automatically detect the data structure.
2. Navigation Step
Navigation = Table.SelectRows(Source, each Text.StartsWith( [Item], "Data") and [Kind] = "Sheet" ){0}?[Data]?
Purpose: Filters and extracts a specific sheet containing data.
Function:
Table.SelectRows: Filters rows in the imported workbook’s data table.
each Text.StartsWith([Item], "Data") and [Kind] = "Sheet": Condition to select rows where the Item column starts with “Data” and the Kind column is “Sheet”.
{0}: Selects the first row from the filtered result.
?[Data]?: Accesses the Data column from the selected row, returning the sheet’s data.
3. in Navigation Step
in
Navigation
Purpose: Specifies the final output of the query.
Function: The transformed data stored in Navigation is returned as the final result of the query.
Summary
Source: Imports the workbook data.
Navigation: Filters for a specific sheet named “Data” and returns its contents.
Final Output: The contents of the targeted sheet.
This code effectively imports an Excel file, identifies a specific sheet, and extracts the data from that sheet for further processing or analysis.
Additional Insights
Common Functions:
Excel.Workbook is frequently used for data loading in Power Query.
Table.SelectRows is essential for filtering table data based on conditions.
Alternative Example
Here’s an example where a different sheet is selected:
Source = Excel.Workbook(File.Contents("PathToWorkbook.xlsx"), null, true),
Sheet2Data = Table.SelectRows(Source, each [Item] = "Sheet2" and [Kind] = "Sheet"){0}?[Data]?
in
Sheet2Data
In this example, it selects the sheet explicitly named “Sheet2” instead of using a dynamic condition.
For a broader understanding of data transformation in M Language and Power Query, consider exploring resources on the Enterprise DNA Platform.
