I have a query on the workbook that contains the query. The file (xlsm) is also password protected. When I don’t have the password on the file the query works when i reinstate the p;/w the query hangs .
What are my options. The most sensitive tab is a salaries tab.
Hi @AllisterB, we’ve noticed that no response has been received from you since 26th of February. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
