Power Query - M (Table. Select)
In your video on Creating Records For Daily Values With Power Query [Creating Records For Daily Values With Power Query | Enterprise DNA]
Require clarification in the following M Code
Table.SelectRows(BufferedTable, (BT)=> BT[ID]= _[ID]and BT[Date]>= _[Date] ))
Table.SelectRows requires only two parameters table and condition as function. The above code compares the current record with the Buffered table .
My question is how does the buffered table gets **automatically assigned to the variable BT in the function (BT) =>, before comparing with current record held by _(underscore)
The function starts comparing the selected columns of the buffered with the current record
@Sairam
()=> is a custom function that doesn’t accept a parameter
(BT)=> is a custom function that accepts a parameter of any type, since BufferedTable is on left it is automatically passed as an argument to this function
more explicitly it passes a record, row by row.
(BT as record ) => is a custom function that accepts a value of type record.
()=> equals each
Thanks @AntrikshSharma
(_)=> invokes Current record ; variable name can also be used in lieu of _underscore .
Hence I was amazed as to how automatic assignment of BufferedTable to the left,is passed as an argument to the function (BT)=>
M is the new paradigm of using codes to extinguish codes. @Melissa is the God of M code.
Hi @Sairam! We noticed that your inquiry was left unsolved for quite some time now.
