I have the following query but it is not grouping right. Based on the information provided, I want to mark “Y” for the smallest positive Date_Difference
within each group of Email
and Campaign Id
. If there is a Date_Difference
of zero, it should take precedence over other positive numbers. All other entries should be marked as “N”.
Thanks for your help.
Here is the query.
#“Added Custom” = Table.AddColumn(#“Removed Other Columns”, “Date_Difference”, each [Became an MQL Date] - [Interaction Date]),
#“Grouped Rows” = Table.Group(#“Added Custom”, {“Email”, “Campaign Id”}, {{“AllRows”, each _, type table [Email=nullable text, Interaction Date=date, Became an MQL Date=date, Campaign Id=text, Date_Difference=duration]}}),
#“Added Custom1” = Table.AddColumn(#“Grouped Rows”, “MinPositiveDifference”, each let
CurrentGroup = [AllRows],
SortedTable = Table.Sort(Table.SelectRows(CurrentGroup, (inner) =>
inner[Date_Difference] >= #duration(0, 0, 0, 0)),{“Date_Difference”, Order.Ascending})
in
if Table.RowCount(SortedTable) = 0 then null else SortedTable{0}[Date_Difference]),
#“Expanded AllRows” = Table.ExpandTableColumn(#“Added Custom1”, “AllRows”, {“Interaction Date”, “Became an MQL Date”, “Date_Difference”}, {“Interaction Date”, “Became an MQL Date”, “Date_Difference”}),
#“Added Custom2” = Table.AddColumn(#“Expanded AllRows”, “Unique MQL per Contact per Campaign”, each
if [Interaction Date] = null or [Became an MQL Date] = null then “N”
else if [Date_Difference] = [MinPositiveDifference] then “Y” else “N”),
#“Sorted Rows” = Table.Sort(#“Added Custom2”,{{“Email”, Order.Ascending}, {“Campaign Id”, Order.Ascending}}),
#“Changed Type” = Table.TransformColumnTypes(#“Sorted Rows”,{{“MinPositiveDifference”, type number}, {“Unique MQL per Contact per Campaign”, type text}})
in
#“Changed Type”
data.xlsx (9.4 KB)
