Attached a sample dataset file with the following columns
Dokter; patient; medecine; date ( prescription date for the medecine )
This bulk information is from a external source and saved in a folder as an XLSX file
I was wondering if it is possible in power Query to filter out the first prescription date for a combination patient/drug or at least an additional column with an indication 1 or 0 for the first prescription date
See attached screenshot
Attached the sample set
Thanks in advance for any suggestion
Roger medecinelist.xlsx (130.4 KB)
I’ll add it here for others to review as well.
Included a second query, with separated steps. Hope that helps clarify it.
Please don’t forget to mark the response that solved your inquiry as solution, just click on the 3 dots. Thanks! eDNA - Occurrence identifier.pbix (13.8 KB)
