Hi ,
Just wondering if there is any way to figure what is going on.
I am a simple model, one to many relationship . Power bi connected to cube.
i have a table but noticed that the total figures is not the same with what i have in my cube and SQL DATABASE.
my data type is whole number and in the SQL database is int.
sometimes the figures looks correct but when i load new data, the figures jumps.
i try to clear the cache still no luck, will appreciate any hint
Hi Marcster,
Not at all. i am just doing a simple SUM(MEASURE) Then place in a table along side two metrics where they are broken down by a single category ( state).
funny enough, when i filter for year 2020, the data is correct but when it is 2019, i get incorrect data. strange
Hi All,
Any help on this.
I decided to truncate the data and load the excel file again then push data to the cube and refresh
This time, the figures increases more so it seem every time i refresh the cube, i get additional figures ?
I need help please
@alora101,
You have to check tables individually to find the bug here.
some hints for you,
Check values in individual tables, if the values are same problem is not in table values.
Then check for relationship. Check the values after adding relationship one by one against cube.
Thanks!
Hi @alora101, did the response provided by the users and experts help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark the thread as solved. Thanks!
