Power BI Service Visual header--More Options disappears
HI Team,
In Power BI Service When I Click the three dots on Visual header then choose More Options, i can see the options but it disappears vary quickly and pages panel on the left side is also flickering
this issue occurred in Power BI services only not in Desktop.
previously My Report work fine but recently, i am facing this issue
when i try with Internet explorer then it’s work fine only not working in MS edge and chrome browsers.
what is causing the issue?
Thanks in advance!
More Option Disapper
Thanks Team, This issue just yesterday occured now i don’t see any issue
might be due to yesterday Google Chrome update that will fixed.
Tested in Firefox and Chrome on a handful of my reports, and not seeing this issue.
does the header overlap another visual perhaps?
Thanks for your,
Welcome to the forum @Ajay :slight_smile:
I hope that you are having a great experience using the Support Forum so far. Kindly take time to answer the Enterprise DNA Forum User Experience Survey, we hope you’ll give your insights on how we can further improve the Support forum.
Thanks!
Hi @Ajay, we’ve noticed that no response has been received from you since Oct 30.
